fuse tapping question
Quick question fellows, I need to add a fuse tap and its calling for the 10 INJ which Im already using for Headlights, Anyone had any luck using another for same purpose basically? lemme know thank you
Most people use something like this: Amazon.com: Nilight 12Pack 12V Car Add-a-Circuit Fuse Tap Standard Mini Micro2 and Low Profile Fuse Taps 4 Types ATO ATC ATM APM Fuse Holder for Cars Trucks Boats,2 Years Warranty - 50062L : Automotive
The only problem I've heard of is this type of fuse tap sits higher off the main board, so a cover may not fit.
I’m assuming you are powering up your coolant pump on your supercharger. I came off of the recommended fuse tap. You might be able to go to the interior fuse box. I’m not sure what else is available under the hood to use.
Jhunt
