Future of car suspension -- DSC Sport’s active shocks
NoDak
Senior Member
Computers are taking over our cars. In the longer term, self-driving vehicles have the potential to make significant cuts to road deaths, congestion, and pollution. Right now though, most of the immediate impact can be seen in infotainment systems. Focus groups have told car OEMs that to appeal to them as customers, they need to replicate the smartphone experience within our cars, which is why LTE modems and large touchscreens are proliferating as rapidly at auto shows as they are at Best Buy. That's OK with us at Ars Technica, because processing power also makes things like DSC Sport's active suspension technology possible, as we found out this past weekend on our trip to Watkins Glen, NY.
First, a little background. Generally, a car's suspension consists of various metal bits that connect the wheels to the chassis—wishbones or struts and so on that allow the wheel to articulate—and some combination of spring and shock absorber to control that articulation. A well-engineered suspension should provide good road-holding (keeping all four tires in optimum contact with the road surface) while also insulating the car and its occupants from bumps and jolts. This is easier said than done. Very few cars are successful at both, with their designers opting instead for soft springs and wallowy comfort at the expense of handling, or stiff springs and great cornering ability combined with a spine-rattling ride.
But active suspension systems promise we can drive our cake and eat it too, using software and CPU cycles to dynamically control what each wheel does. The technology came to the attention of the general public in the 1980s, thanks to its use in Formula 1 back when its rulebook encouraged innovation. Early active systems used in F1 used hydraulic actuators to control wheel movement. The aim was to keep the car as flat and level to the ground as possible. The constant ride height kept the car's wings at their optimum angles for creating downforce—think of the exact opposite of a plane's wing, where the air pushes the car (and therefore the tires) down onto the road. Lotus Cars were an early pioneer of such active systems, but they were always too complex and too expensive for use beyond a number of technology demonstrators.
F1 soon banned active suspension, but the principle has appeared on road cars and motorbikes over the year with computer-controlled shock absorbers. Again, the idea is to keep the suspended car as stable as possible. Normally, a car's weight transfers from front to back as it brakes and accelerates, and from side to side as it corners. As the force on each corner changes, so does the grip available to that wheel; less weight equals less grip. Active shocks control this by varying the degree to which each spring's compresses and extends (as the springs are passive, these systems are sometimes known as semi-active).
The Audi RS7 we drove to Watkins Glen and back was equipped with such a system, which links the shocks on opposite diagonal corners (front left to rear right and vice versa) to each other via a central reservoir of hydraulic fluid, as did the Porsche 911S and Corvette Stingray we wrote about earlier this year (the latter uses magnets to alter the viscosity of the fluid in its shock absorbers).
DSC Sport's system is closer to the Audi's, but more capable than either, according to founder Mike Levitas. He has been developing his control system since 2011, which plugs into the car's CANbus—the Controller Area Network that allows all the different subsystems to communicate with each other. Once installed on the CANbus, it constantly samples the amount of brake pressure and steering input being applied, the throttle position and load on the engine, as well as G force and acceleration.
Levitas has been refining the active suspension on the racetrack, competing in the IMSA Porsche GT3 Cup with his team, TPC Racing. The setup in his race car couples the ECU with dutch-made TracTive shock absorbers. The ECU pulls in 1Mbps data from the CANbus, and controls the shocks at 100Hz—every 6 milliseconds, which Levitas describes as "near-enough real-time." Valves alter the flow of damping fluid through the shock absorber, changing its response rate and thereby the speed and amount at which it compresses and extends
His race car (a 997 model) has now been superseded by the newer 991 GT3 Cup, a car that should by all rights be faster on track. Levitas is an experienced racer, but even so he credited his success this past weekend—winning his class in the dry on Friday and the torrential rain on Saturday—to the suspension. In the wet he was particularly fast, troubling the newer 991 cars at the front of the pack.
He also had a road car demonstrator at the track, putting it through its paces for us on the back roads around Watkins Glen. That car is a Porsche Boxster Spyder, a lightweight (2,900lb/1,315kg) special edition that saw out the last-generation Boxster). The Boxster Spyder has also been given a bit more oomph thanks to a turbocharger (complete with methanol injection), putting out more than 500hp to the rear wheels.
Light weight and lots of power often make a car a handful to drive, but the Boxster Spyder's road manners were excellent, never once stepping out of line. The road car was only sampling the CANbus at half the rate (512kbps) of the racing car, but it shrugged off railway tracks and potholes, firming up the front to prevent it from diving under braking and the rear under acceleration to keep the car constantly traveling in the right direction.
DSC Sport has sold more than 500 systems, and it's not restricted to Porsches either; DSC Sport has Dodge Vipers among its customers, as well as Nissan GT-Rs. As long as a car uses CANbus it should be compatible, although DSC Sport have to 'sniff' out how each model uses CANbus as manufacturers have different ways of implementing the spec. It's not even particularly expensive—$1,200 for the ECU—and there appears to be a quite active user community who share different ECU maps and data with each other and DSC Sport.
The benefits? Faster lap times on track and better manners on the road, to name two, but there are other payoffs as well. Reduced driver fatigue, for one. Less wear and tear on the car too; Levitas' rear tires looked box-fresh after the race on Friday. Now that we've experienced the active suspension from the right-hand side of the car, we can't wait to try it out from behind the wheel.
original article : The future of car suspension is here: DSC Sport?s active shocks in action | Ars Technica
Interesting... I wonder how he's getting permission/coding to access various datalists. For example on a Toyota the ABS is on a completely different physical network than the CAN Bus.
I'm pretty pleased with the (semi) active suspension on my newest bike. I can choose a cushy ride on-the-fly for droning down a bumpy interstate, or firm it up for carving through a smooth, curvy road.
