Gear Oil Question
Gear Oil Story
I want to post a relevant story about 4Runners and gear oil. I have learned a lot from this website and I want to pass my experience on to others.
I own a ’98 4Runner (3.4L-V6, 4WD) I bought used in 2008. It had 134,000 miles on it and the CarFax listed several owners, the first of which, when it was new, as a vehicle leasing company. That should have been my first warning sign.
At 137,950 miles, I had the front and rear differential and the transfer case oils all changed. The mechanic that did the work told me all the oils looked as though they hadn’t been changed since the vehicle was new. He specifically said the rear differential’s oil looked bad. Warning sign number 2.
At the 177,370 mark, I started to hear a low hum at highway speeds. I thought the sound was coming from the front end so I specifically took it to a Toyota dealer to diagnosis the sound but they found nothing. Warning sign number 3.
At 180,000 miles, I changed the oils in the two differentials and the transfer case again, but this time I did the work myself and I researched the exact oil to use in all 3. And just as every other Toyota customer has found, I could not find a single weight oil (Toyota specified 90W oil in the rear diff on the ‘98 4Runner).
Like everyone else here, I got on the internet and searched, and saw where other 4Runner users were using multi-weight oil but there was always a debate on what particular choice of multi-weight oil. After lots of research and reading of posts (several of which were on this website), I finally chose Mobil 1 Synthetic 75W-90 gear oil. The 75W-90 weight oil was exactly what Toyota called for in both the front differential and the transfer case, but I was a little hesitant to use it in the rear differential. I finally took the plunge and put it in all 3.
Over time the hum sound got so loud I wore ear plugs when I drove at highway speeds for long distances. At 193,300 miles I took it to another mechanic and he said it was the carrier bearing of the rear differential. In mechanic’s speak it’s called it the “3rd member” with the 3rd member being the rear differential.
I had him install a Jasper Engine remanufactured rear differential which came with a 3 year/100,000 miles warranty. The mechanic told me to use the exact oil that Toyota recommended (i.e. SAE 90W) or it would void the Jasper warranty.
Remembering that I had had trouble locating 90W oil before, I asked what oil did he put in the differential when he installed it? He said Jasper ships the oil they want used in the differential so he doesn’t have to choose.
I then asked if the 75W-90 Mobil 1 gear oil could have caused the bearing to go out but he wouldn’t give a specific answer one way or another. When I asked if M1 75W-90 oil would be OK in the remanufactured differential, he again said “use exactly what the manufacturer recommends” so he was no help at all.
I called Jasper and they said the same thing as the mechanic: use SAE 90W oil. The customer service representative even looked up the spec.’s on the vehicle while I was on the phone with him. When I told him you can’t find single weight oil, he offered no compromise but simply said: “Jasper recommends you follow the manufacturer’s recommendations.” The reason I was so particular on the weight oil to use is I was concerned that use of the M1 75W-90 may have caused the rear differential to fail and I wanted to abide by Jasper’s warranty.
After the Jasper recommended 5,000 mile break-in period , I began to search for 90W oil and again couldn’t find any. I even visited a Toyota dealer and inquired about purchasing gear oil and was told they don’t sell it directly to the customer.
I got on the Toyota website and emailed their customer service regarding what oil to use. They emailed back and directed me to visit another Toyota dealer. I visited a 2nd dealer and was told the same thing as the first dealer (they don’t sell in quantities to the customer), but the 2nd dealer did say he thought M1 75W-90 would be fine for the differential.
I called a 3rd Toyota dealer and he told me: “of course you can’t find single weight oil that’s why we use multi-weight oil!” He even went so far to say they use 80W-90 or 85W-90 weight (he couldn’t remember which it was—he said he would have to look at the label on the oil drum). I thanked him and told him he had told me more than the other 2 dealers had on what they use in the service department.
I went to Advance Auto Parts and told their counter salesmen my story. One said he was a former Toyota mechanic and he confirmed they use multi-grade oil. He and another salesman both agreed that the M1 oil I used did not cause the rear differential to fail but it was probably due to the clean oil flushing out all the sludge from inside the bearing that had accumulated due to the lack of oil changes from the previous owners.
One salesman even said his wife’s used car is doing the same thing—he changed the rear differential oil, the oil looked very bad and had not been serviced regularly, and he now hears a noise coming from it. He said it probably won’t be long and it will go out too. After discussing it with them, I finally decided on Lucas Oil 80W-90 gear oil.
Armed with this new information, I contemplated Toyota’s first email response where I got the run around and finally decided to email them back that I was going to use 80W-90 since that was the closest I could find to 90W. I also stated I was going to send a CC of my email to Jasper with the idea I could prove I did my part as an owner/operator to see I used the correct oil when and if I had to use Jasper’s warranty.
I immediately got a reply within 2 hours or so (versus 2 days for my first email) and from someone different than my first reply. This entire email is below:
Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
We are sorry for the difficulty you have experienced with locating the appropriate weight oil for the rear differential in your 1998 4Runner.
We do realize that single weight oils are no longer available, thus, Toyota Motor Sales, U.S.A., Inc. recommends and approves the use of multi weight oils such as 85W/90, as when operated they reach the 90W rating at normal operating temperatures.
Also, since Jasper is not a Toyota company, we may not advise on their warranty policies. We would recommend contacting them directly regarding any warranty questions.
We truly apologize for any inconvenience this matter has caused you.
If you have any other questions, please feel free to contact us via email by using the following link, Toyota Help or by calling 800-331-4331. We are available from 5 AM to 6 PM, Pacific Time, Monday through Friday and from 7 AM to 4 PM on Saturday.
Sincerely,
Anita Mouton
I found it rather amusing that Ms. Mouton clearly admitted that “We do realize that single weight oils are no longer available....” and she also gave a recommendation of 85W/90 gear oil. What I fail to understand is why this was not told to me in their first reply to my original email.
I wish now I had used the M1 75W-90 oil as I received Ms. Mouton’s email after I had already installed the Lucas 80W-90 oil. I am now giving serious thought to switching back to M1 75W-90 as I feel from her reply it would be sufficient. Like many of you here, I am a big fan of synthetic oils.
I hope this story can be of some good use for other 4Runner owners.
HI guys i have a question that I have a self propelled Snapper push mower that i found in the garbage with a Ninja mulching blade. The mower runs okay, but the transmission is tired. I have a used transmission ready to install on it, but i want to replace the gear oil in it first. What type of gear oil should i use?
The Honda hydrostatics use 10w-30 motor oil. Kinda weird question for a Toyota 4runner forum, though.
-E
this guy posted odd questions ALL over the place. Likely just trolling for responses on as many forums as he can find. Maybe bored?
trololololol
Royal Purple here, lil extra $ didn't bother me cause I won't be changing it again for a while.
im runing that right now, 75w90 lucas oil, get it off summit racing and just buy couple of gallon jugs, its alot cheaper.
Agreed. After much research I opted for dealership service for gear oil changes. They would not even tell me what weight they used. After many headaches found they used synthetic 75w90 in front and rear differentials and transfer case. Next change will be Amsoil severe gear 75w90 even though latest TSB states synthetic 75w85. I think Redline makes it but not sure, have to check. Disappointed with local dealership.
Not sure if it applies to Toyota axles, but lots of axle makers including Dana which is a giant in the axle industry recommend that you DO NOT use synthetic oils in the differentials.
Syn. oils are debatable in engines with lots of friction parts... but for a gearset you don't really want that "slippery" nature of the oil. You just want to keep things cool and lubed and syn. oils over time can actually cause more wear and shorter life.
I once had a Jeep with a Chrysler Corporate 8.25 axle which was regarded as a very bulletproof design. I put syn. fluid in it and immediately had chattering issues and noise. Drained it and put $3/quart walmart fluid back in and it ran smooth as butter from then on.
Now days the only thing I buy is the "cheap" axle fluid. Change it when needed and don't worry about it. It's a simple gearset...not a high tech engine.
pax at 4
