Getting some rubbing on Upper Control A Arms, What to do??
gkatmar
I noticed the other day that I am getting some rubbing on my upper A Arms. I currently have an OME set up and 275/70/17 tires. I took some pictures, you can see where the tire is hitting the A Arms. Is this ok or should I look into replacing them. I do not do any serious off roading. Please help. Thanks
IMG00045.jpg~original
IMG00044.jpg~original
IMG00043.jpg~original
IMG00042.jpg~original
IMG00041.jpg~original
IMG00040.jpg~original
wheel spacers
prolly your cheapest solution...
spidertrax seems to be the best and they run a lil over $200.
hope that helps
You can also change the UCA's to Total Chaos or Camberg which should eliminate the rubbing. A bit more expensive, but less stress and more responsive than the stock with the larger tires.
Deelock
