Akkording
Member
The Nitto Ridge Grappler and Toyo A/T 3 are available in 285/75 C
thank you, I'll look into them.
waiting to get my truck back, its in the shop getting 285/75r17 nitto ridge grappler load c.
already had a bmc done a while ago. fingers crossed. might or might not do a regear depending on how it drives. i have a urd whipple supercharger.
I think a 265/80 would be an ideal size and 275/75 would be pretty good too, but they don't exist. If you want the look of a bigger tire 255/80 might not be the answer. That's what I've been using for a few years and while they work great they just don't look too great.
Were they not wide enough for your wheels? or just too pizza cutterish
285/75r17 installed
full size spare fits, cleared panhard bar by maybe a pinkys worth of space
I figured it would fit if you didn't have KDSS.
A 255 just looks small in the wheel well until you push it way out, then it causes some fitment issues. I use the stock Trail wheels and then added spider trax spacers. After adding the spacers I had to BMC, cut the bumper, and do fender liner mods front and rear. It still rubs when I'm wheeling, it even rubs the BMC. I think the BMC I went with (SDHQ) was actually just not a very good design, but that's another story.
But with the correct offset wheels there may be a happy medium. It is hard to find wheels with various offsets that would not be really wide for a 255, and I can't afford to experiment lol.
All that said they are a great tire... it was purely aesthetics that made mine a pain in the @$$, which is why I said if you want the look of bigger tires.
If you aren't stuck on Nitto Ridge Grapplers, go with some BFG KO2's (Load Range C) in 285 and save weight from any of the RG's you just listed. They come in at 51 lbs.Question - did they rub before adding the wheel spacers?
Also can you post some pics of how they looked small in the wheel well?
I'm really considering the Nitto Ridge Grappler LT255/80R17 33.31 inch size tire for the weight savings (54.96lbs) over the Nitto RG 285/295 (64.4 lbs / 65.08lbs).
Have you considered cutting the bumper flush with the flare and capping the end? It would look killer.285/75r17 installed
I have 34.1” 285/75R17. On my Instagram in my “mods” highlight I show basically what it took; very minimal in my opinion, in addition to a BMC.
My IG link [MENTION=536139]TRDHULK[/MENTION] is in my sig
