Good location for the URD Calibrator?
masphx
I'm in the middle of installing the 7th injector kit. I see most people install that calibrator unit at the passenger kick plate area. I'm assuming that the area is clear on most 4Runner but mine has a ABS module and some larger wire hookup running though that area. Any other good areas to mount this thing?
If your talking about the URD controller for the 7th injector.
I put mines in the passenger kicked panel and put dielectric grease in the connectors just cause I felt it was on the low side of the body.
I also ran the USB cable up through the glove box so I can have easy access to reprogram it after figuring out my initial settings.
2001ATL
