Good Old Tune Up Thread
4Running Daily
Time to drop some cash on a Tune-Up. I'm almost at 160,000 and get 16mpg all the time no matter what. This is purely a drivetrain tune-up. Steering Components/Bushing/Balljoints etc will come within the next couple months.
Color Codes:
Black= Not Ordered
Orange = Ordered/Shipped
Red = Arrived/Bought
List:
- Toyota Fuel Filter Part #23300-62030 $44
- Toyota Oil Filter Part #90915-YZZD1 $5
- Toyota PCV Valve $11
- Engine Oil 5W-30 $28
- Transfer Case Fluid $10
- Front and Rear Differential Fluid $32
- Air Filter $23
- Borla XR-1 Muffler Part #Borla 40942 $140
- Redline Transmission Fluid Part #50304 $45
- NGK Plugs and Wires Part #4412 $30
- NGK Spark Plugs Part #3967 $30
- Can of Seafoam $8
- Can of Throttle Body Cleaner
$5
- MAF Cleaner $8
- Can of PB Plaster $6
- Medium Thread Lock $4
- Various Washers and such $15
TOY 90430-18008 TC Fill/Drain Gasket 27 Ft-Lb
NAPA ATM PB2403 TC Fill/Drain Gasket 27 Ft-Lb
TOY 12157-10010 Front Diff. Fill Gasket 29 Ft-Lb
TOY 90430-24003 Front Diff. Drain Gasket 48 Ft-Lb
TOY 90341-18006 Rear Diff Fill Plug 36 Ft-Lb 24mm skt.
TOY 12157-10010 Rear Diff. Fill/Drain Gasket 36 Ft-Lb
TOY 90430-18008 5-speed Fill/Drain Gasket
NAPA ATM PB2403 5-speed Fill/Drain Gasket
Total for Parts only: $444
Total for Labor: $95
Absolute Total: $539
Seafoam Video!
Borla Muffler Video!
Feel free to tell me if I'm missing anything.
PCV valve
Toyota Red or Pink Coolant for flush depending on time since last
Looks good Connor. Gap the plugs. Also buy some CNC MAF cleaner and clean the MAF if you have not done so before. Being too lazy to check your build link, how about an air filter cleaning or replacement?
If you are set on Seafoaming, check this video out. I'd Seafoam first before anything else:
Seafoam Intake 99 4runner - YouTube
I will gap the plugs to .0043 or .043 whatever it is.
I'll put MAF cleaner on the list. Thanks.
Air Filter is already on the list
Thanks for the seafoam vid!
Redline is good stuff, no doubt about it. If you have deep pockets, it would be the way to go, at least for me. I am using the D4 in my auto. I don't know what is recommended in the 5spd, maybe MTL, or MT-90.
Amsoil is good stuff as well.
I'm Redline Mt-90 is what will be in my trans. My pockets aren't that deep though.
So Amsoil in the Diffs and Transfer Case. What weight? GL-4 or GL-5?
80w90 in the rear. Amsoil actually recommends 75w-110 severe gear if you do a good bit of off-roading. I cannot remember why exactly. You can always email them.
I like to use Chevron Delo 400 80w-90 in the rear diff.
75w-90 in the front diff and transfer case. Mobil 1 here for me.
Just spent $65 at the Toyota dealer for a PCV Valve, Fuel Filter, and an Oil Filter.
Then I spent $120 at Autozone on Engine Oil, Tranfercase Fluid, Front and Rear diff fluid, and airfilter, and MAF cleaner.
They don't call it the stealership for nothing eh Connor? I have to ask how much the oil filter cost ya? I know the PCV valve lists for $6 and change. If you do not have new crush washers for the diff and transfer bolts, pay them another visit.
I take it you already have the Seafoam?
Oil filter was $5. The PCV was $11. Now I need some crush washers? One for the front diff, one for the transfer case, one for the transmission, and one for the rear diff?
Good luck with the maintenance dude. You made the right call.
Thanks!
Thanks!
Ouch!! NAPA Echlin Part No. CRB29352 costs $3.87. I change it every 30k with my spark plugs. Works just fine.
NAPA AUTO PARTS
Each box uses two crush washers--drain and fill. You can reuse them once without any real problem, but at some point they get weak and break.
The rear diff fill plug number is on the list because it is real easy to round off, use a 24mm six-point socket, apply PB Blaster night before, and bang it a few times with a hammer before turning out. Anti-seize on the thread makes it easier the next time.
How hard is it to clean the throttle body? Is this something that should be done frequently?
A tooth brush and some TB cleaner. This is the first time I've cleaned mine in 160,000 miles. Pretty easy to do.
By the way guys, I'm continuing to update the first post as time goes on.
