Greasing the drive shaft
bassmacka
Member
I have some questions. From what I gathered from this thread
http://www.toyota-4runner.org/maintenance-detailing/220638-greasing-driveshaft-4th-gen.html
What I need are 2 kinds of grease one lithium grease and one lithium grease with molybdenum disulphide.
Do I need 2 grease guns then? I can pick these up at walmart or autozone? Other than that it seems pretty straight forward. I hope it does improve the drive line clunk. If you anyone has any additional tips or info please chime in.
No additional info. You are correct. 2 guns 2 different tubes of grease unless you want to buy one grease gun and put a tube in for like 6 pumps then pull the tube out and purge it with the other grease. Not a fun time.
Good timing on this thread... its been on my to-do list for a while but I haven't researched it yet...
EricTheCarGuy makes some good videos... I like his channel
I was looking at my zerks last night when I was doing my brakes... some of those things are in some pretty cramped areas.
I might need to look into some better fittings. My existing grease gun isn't looking so great...
Being the stickler for following the factory recommendations, I will probably get the two different greases that are called out in the service manual, but I am sure that using one grease across the board isn't really a problem if its a good grease. I bet it happens a lot more than you think when you take a car in for service somewhere.
two grease guns . the reason to use moly is because the grease will not blow out much and will stick in the slip yokes longer then just lithium .
on slip yoke do 1/2 pumps until you feel some back pressure then stop . probably 2 -4 half pumps slow not hard pumping..
on the U joints pump lithium grease till it comes out then wipe it all down ..
clunk on stop then start is the binding yokes common on all trucks.
My drive-line isn't very noisy or clunky... Perhaps I should just leave it alone...
That said, I have no idea when the last time it was serviced, or if its ever been done.
Two guns... I was using the stuff without moly for awhile and noticed that I had to grease it every couple of weeks. Dropped the drive line, cleaned out all the splines then used the correct stuff and can go months now with out having to grease it. It also helped that I cleaned up the slip yoke with some emery cloth.
There's a reason the engineers recommend two types of grease and its not just about making money off customers... I've slowly learned, by trial and error, that they just might be smarter that me...
I use non-moly grease for both, and it works fine, but moly grease in the appropriate areas would be better. I usually grease them about once every oil change.
So I've been doing it wrong all this time.... thanks :hunter:
I have no idea what kinda grease I've been using. All I know is it doesn't taste like bacon grease.....
in another thread they were talking about using 2 different kinds of greases and i forget who said it but someone said they ended up taking that part of the owners manual in the later years? that one type of grease is ok, and seems like everyone was using the mobile 1 pinkish/redish grease, I'm going to grease up everything this sunday.
My first oil change & lub is coming up on my Gen3 - I bought AMSOIL DOMINATOR Synthetic Racing Grease NLGI#2, for one brand-fits-all.
Amsoil - Synthetic Heavy Greases
MSOIL Synthetic Polymeric Off-Road Heavy-Duty Moly Grease – EP NLGI 1, NLGI 2
Moly Grease: AMSOIL Synthetic Heavy-Duty EP NLGI 1, 2
Combines a Calcium-Sulfonate Complex Thickener and Proprietary Synthetic Polymeric Technology for Enhanced Extreme-Pressure (EP) Performance
Moly-Fortified to Meet Caterpillar’s 5% Moly Requirements for Bushing and Pin Applications
Resists Pound Out and Water Washout in Heavy Equipment
Woody
Lubrication: Is grease just grease? [Archive] - Lawn Service Forum
The whole "never mix grease of different types" is very valid. But, what thye are talking about is mixing grease containing a LITHIUM soap with a grease containing a SODIUM soap. I haven't seen a sodium soap based grease in more than 20 years (at least). Everything I have seen in recent times is lithium soap based.
Molybdenum disulfide (MoS2), or "moly" for short, is an outstanding dry-film lubricant. It has a coeffecient of friction nearly identical to (or sometimes better than) Teflon, WHITHOUT all of the problems associated with Teflon (and there are so many with Teflon that it would take a near encyclopedia sized post to even begin discussing it). Moly also works VERY well as an extreme pressure lubricant (something Teflon can't do), and so is added to "EP", or Extreme Pressure greases. The problem is that nearly all EP greases are for LOW SPEED applications. This means they function well on things like pivot points and such (most zerks on a mower), but function rather poorly on high speed items, like spindles or wheel bearings on cars. By the same token, multi-purpose greases usually perform well with higher speed uses, but fail to give extreme pressure performance in low speed applications.
Personally, I have found ONE grease that is truly a "one grease for everything". It even exceeds the Ford specification for wheel bearings on disk brake equipped cars (Ford M1C75B) WITHOUT the addition of molybdenum. This is quite a task, and is the only grease in the world (that I know of) that can do this. It works outstanding at low and high temperatures, under extreme pressure applications, low and high speeds, etc. This grease is Amsoil Series 2000 Synthetic Racing Grease.
Once my currently used grease runs out (and it is about out), I will be switching to the Amsoil Series 2000 grease. While not an Amsoil representative or affiliate, I do highly recommend this product.
Amsoil Series 2000 (AMSOIL - 404)
hardboiled
I believe Amsoils leaves the moly out of the wheel bearing grease because of its affinity to hold heat. As you said Woody, thats better suited for high load low speed uses. U-joints, Fifth wheels, slack adjusters. I use the 2000 racing grease also,good grease for trimmer heads. Good resistance to wash out, too.
drayb307
Mucho Thanks for all the input guys!!! I had purchased some "Slick 50 One Grease" and was having second thoughts about using it for everything. I feel much more comfortable about using it now.
Woody: I appreciate the depth of your reply. You, obviously, do a fair amount of research. The Slick 50 I have is supposed to meet or exceed all requirements for #2 NLGI Service Classification GC-LB. I think it will be worth trying. Good luck to you with the Amsoil Series 2000!
Woody
Mike, believe it or not, I think I priced it out at around $5.00 a tube. I forget how many I had to buy at a time though. At least I THINK I found it that cheap.
Hardboiled:
Amsoil leaves the moly out because they can acheive a high film strength without it (quite a feat). Molybdenum doesn't hold the heat in, or any other detrimental thing I have heard before (and I have heard some in my days). It is actually quite a lubricant.
Mike:
To cover all bases I was using a grease that met the Ford M1C75B specification (I believe it is just the standard Valvoline "Ford" type grease). This means it prevents wear in high load/high speed applications. That Valvoline Synthetic LOOKS GOOD on the label, but when you corner them and ask if it meets the Ford spec, they will ADMIT that it DOESN'T! So stay away from the Valvoline SYNTHETIC. Anyhow, anything that meets Ford M1C75B will prevent wear on the spindle bearings in a big way, and will be more than adequate for all pivot points as well.
Woody
Hardboiled:
Amsoil leaves the moly out because they can achieve a high film strength without it (quite a feat). Molybdenum doesn't hold the heat in, or any other detrimental thing I have heard before (and I have heard some in my days). It is actually quite a lubricant.
Mike:
AMSOIL GPOR Synthetic Polymeric Off-Road Grease 5% Moly
http://www.syntheticlubricants.ca/CMFiles/General Files/Product PDF Files/GPOR.pdf
I use the redline CV-2 grease for u-joints and slip shafts.
But then again I like to live on the wild side :guitar3: lol
I use one type also, Royal Purple Ultra Performance Grease.
2 pumps from a full size grease gun to the zerks every oil change for me.
So far so good.
IMO...Your making a simple grease job way too complicated. I strongly suggest you get a high quality Marine Grease and be done with it. There is a difference in the Marine Grease in how it reacts to temp, water, and cold....yes its a tiny bit more expensive...but well worth it. I use Amzoil...in everything except high volume constant fill/re-grease stuff like equipment. In those standard grease works great....I prefer the LUCAS Red and Tacky.
many do have your opinion , if it works ignore it. however the manual states these do need lubrication.. so if you wait till it then is an issue that means its worn out.
this takes maybe 10 min the first time you do it.
johnnya
