Greasing the IFS steering knuckle.
GeoRoss
I was perusing the FSM on what grease to use on the drive shafts and u-joints. Not only did I learn there is a double cardon joint, but there are steering knuckles to grease. Learn something every day on the 4Runner. I assume you just clean and remove the screw plugs and put in a few pumps of moly. Anyone replace the screw plugs with zirc fittings? I think I can do it with out removing tires, but I guess I'll need a needle fitting for my grease gun. anyone have any tips?
my '87 has zerks, not plugs, for the upper and lower ball joints.
Replacing the screws with zerk fittings sounds like a great idea but a needle attachment for a grease gun is a handy and inexpensive tool. I was having a terrible, intermittent vibration and sound coming from my front wheel and finally narrowed it down to the axle shaft bushing in the steering knuckle. LandCruiserPhil's instructions, post #10 of this thread, are incredibly easy for this often overlooked maintenance procedure. If you're in that area with a grease gun already, you might as well get two birds.
AlaskaRuss
