Grill for BBQ question
Iman74
Help me find this.
Here is the deal. I own a Home Depot issued (quite a few years old) Charbroil grill. I just moved into a new home that has a huge tank outside that provides gas for our gas fire place. There is a second hose going from the tank to a small hole in the deck obviously for a grill. The grill we own is a standard connector that screws into the tank itself. The hose from the big tank is a (I think 3/8) nut. I need an adapter that goes from that hose to the connector on the grill hose (that would normally go right to the tank).
So far I yet to find something in Home Depot but does not mean it is not there, and www.charbroil.com website I did not find anything either.
I do not think this is grill specific for from what I can see all grills have the same connector to screw into the takes, so I think the adaptor would work for any grill.
I set up the same thing at my house.
First get rid of the regulator on your grill.
then it should be easy to hook up.
The regulator on your grill is made for
full tank pressure so it has to go.
the regulator on your house tank has a pressure of only 10 to 14 inches of water
pressure. so if you use the regulator on your grill you will get nothing.
Hope this helps:p
erinobr2000
