Grill mod- mesh, not satoshi
1da4
I have a 2001 Limited and I hated the grill; it was the only chrome thing on the car and the plastic inserts were scratched to hell and it was just ugly. So I made my own grill insert because I didn't want to buy a whole new grill to do the satoshi
Result:
And heres how I did it:
Took the grill off, sprayed some plastic adhesive black primer on it then got to cutting with a Dremel; this was the first cut:
Second round of cutting:
Then I bought some 13 gauge metal mesh from Ace Hardware; took some cardboard and made cardboard cutouts of the size of the insert then traced it onto the mesh and got to cutting:
Then painted the grill gloss black:
Here are the inserts I cut:
See the tabs on all sides of the mesh? I cut it like that then bent those backward which then served as my mounting points- After bending them back i drilled holes in the plastic and found very small hardware (nuts, bolts and washers) from the hardware store and mounted it that way- bolt through mesh and plastic grill, nut on other side.
Nice look! It reminds me of those grilles that are sold through the aftermarket auto parts stores for way more than they are worth. Great DIY!
