Grill replace or something more?
Satchmo
So I have this problem occurring.
Do I need to replace my entire grill to fix it? The plastic clips attached to the screws seem to work fine but the damn thing keeps popping out.
If that's the same as mine, the corner light has tabs that slide into slots on the grill assembly, then the trailing edge (fender side) gets screwed in. Check to make sure the slots are still intact on the grill side, and the tabs have not broken off on the light assembly. Other than that, I'm not sure what to suggest. Best of luck!
Not 15 minutes ago I got tired of the same problem on mine. My solution was a little ghetto, but hey it worked. I drilled two holes, one in the grill and one in the light frame. ZIP TIE!!!!
I zip tied my grill on as well... the tabs didn't have screws and I didn't want to bother with it yet. As for getting the side lights back on I would probably use silicon sealer and tape to hold it till dry. That way you can get it apart again.
