(Group Buy) Techstream diagnostic cables to fit your win-7, 8 or 10 (32-64) OS
Just got time to install but look my disc that came in the mail is broken �� tried it any way but no luck keeps spitting it out
can some one copy the cd for me please
Ok, I got everything working! Here's what I did:
- The cable installed automatically - as far as I can tell the drivers are included with Windows. If that doesn't work for others let me know, and I can post the driver it's using.
- I don't have a CD drive on my laptop, but I already had a copy of Techstream (version 12, in cast it matters). It had a registry edit to allow Techstream to use this cable. That can be found here: https://drive.google.com/open?id=1KNYtuYCosZ1nkcLweKO8cITOJDCkOlc4
and I took a quick look at it to make sure it doesn't do anything malicious - I'm not an expert, but it looks ok to me.
Once I ran that and restarted Techstream, I was able to go to System -> VIM select, and there was an XHorse option which worked perfectly.
One other note - it bugs me to install a specific (old) version of Java every time I run it, but it hasn't caused any problems yet to not have it.
If anyone runs into problems let me know, and I can try to help troubleshoot.
I got my cable yesterday (thanks eHaze!), but haven't had a chance to play with it yet. I'll report back.
What firmware version is on the cable? Is it 1.4.1 or 2.0.1? As a mobile programmer, I read a lot into these cheap/clone cables. If you're going to do diagnostics, you should be fine. Programming with these are a huge no-no. Last thing you want to do is have the cable die out in the middle of a reflash.
version of windows?
32 or 64bit?
I bought the cheapest Mini VCI cable I could find on a Ebay and it fried the USB port on my laptop.
Then I bought an other Mini VCI cable and made sure to get one with firmware 2.0.4 which cost quite a bit more. This one seems to work perfectly.
i have several of these kits left if anyone is looking for one.
~$17 depending on your shipping address.
the software is not a plug n' play solution and will require some basic PC knowledge to get it up and running.
I purchased the cable a couple of weeks ago from the ebay seller mentioned on the first post and I was able to install the Techstream software (13.00.022) on Windows 10 (64-bit). The app launches fine and I can connect to the car and see several modules. However, when I try to read the TPMS codes/values, the application crashes. Anyone else having issues with the app or has been to successfully read the TPMS sensor codes?
Yes, you need the older version on the software. The seller should prove u with a libk
