why would you do that when there are tons of aftermarket suspension parts for the 4runner that i am sure are better than the gx?
Agreed,
Here are 3 options to get a small rear lift:
0-2" Firestone airbags via toytec
1 1/2" spacers via toytec or daystar
2" OME 895e springs via toytec
And for the front just get the 5100's and set at 1.75" or get the 883/895e combo and that should yield almost 2" at all 4 corners.
I was told today that these are no longer available by ARB and by Wheelers off road , Toytec has no clue about them either and said never heard of them.
If you know who has them , speak up. All OME stuff is 3" front or back for the 5th generation.
Newby here....so I may be wrong. But I think the above OME setup will provide a 1.5-2.0 lift when combined with stock shocks. When combined with OME shocks it is a 3' lift. Maybe that's where the confusion lies?
The OME's are still listed on the Toytec website. I hope they're still available b/c this is my "Plan-B".
883's:
Front OME Lift Coils - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
895e's:
Rear OME 895 & 895E Rear Coils (FJ & 03-09 4Run) - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
Yep wrong: 883's with OEM or OME will be 1.5"-1.75", 895e's with OEM or OME shocks will give 1.5"-1.75".
Shocks don't provide ride height (5100's change the spring perch placement thus putting more compression on the spring providing a lift), but other than those just shocks will not provide any lift.
Thanks for the clarification.
Does that apply to both front and rear 5100's? if you combined the above OME setup with 5100's front/ rear rather than keeping stock shocks would the lift remain 1.5-1.75?
