Has Anyone done REMOVAL of JBL & direct wiring..
trdsport
Like the title says..has anyone done removal of JBL amp & direct wired to speakers. I am trying to eliminate the sub...thanks.
do you have an aftermarket radio though? if you want to disable the sub, why not take the panel apart and unplug the speaker lead to it?
Thanks for reply, I see 2 connectors, i believe one is for pwr and other (lots of wires) for speaker input and output within that connector. By splicing the later said one..and looping to the outputs of respective speakers it work i guess. Its gonna be a challenge to check every speaker thou.
Yes. I installed an aftermarket radio, 5 channel amp under the passenger seat, component speakers in the front doors, and a new JL subwoofer in the stock enclosure. Bridged the front speakers from the amp - not running rear door speakers. Retained factory steering wheel controls. Installed a backup camera too. I ran new speaker wire to the front doors from the amplifier. Did not want to bother with the stock wiring (as someone said above, ALL speakers are getting their signal from the wiring at the JBL amplifier.)
If you want to reuse stock wiring, you can use this: https://www1.crutchfield.com/p_120708117/Metra-70-8117-Amp-Bypass-Harness.html?tp=3486
It will require you to run wiring from the headunit, back to the stock amplifier location, for each speaker.
What are your goals?
