HaydenATX's '15 TE-The Yeti
How's the output?
Bright as hell and very concentrated. More spotlight than floodlight.
Ditch light only.
Ditch lights plus HID low beams(still warming up so they're blue in the photo.)
Do you have a multimeter?
Unplug the light and see if you're getting power to the plug. If not, trace back to the relay.
The dude at my off-road shop said that doing ditch lights like this may cause issues. He mentioned running them through a fuse rather than straight to the battery. Does anyone know if this is true? Seems like a simple set up just a closed circuit to the battery...
i *believe* it is best for protecting the battery and the ditch lights to have a fuse, and possibly even wire it all through a relay. It's just good practice i believe, but the resident electrical gurus here like [MENTION=65614]Antman[/MENTION] and [MENTION=83083]rigtec[/MENTION] can probably describe it better than i can.
:hippie:
:hippie:
Yea it sounds like a relay is a good idea. The harness that came with the Rigid duallys I got has a fuse and the install instructions have no mention of using a relay. Not sure why.
What shop do you go to? Also in Austin and I'll be needing a place pretty soon.
Today some Toyota marketing folks came in to the office. They were from the "truck and SUV" marketing department. I made sure to park where they would see my truck. When I was introduced to them I told them I was a huge fan and drove a 4Runner. They asked if the 4runner out front was mine and when I confirmed they all told me that I did a "great job" with it. I fanboyed out a little.
Their ride:
Got a hitchgate solo to carry the spare. I'm pretty stoked about this! Very sturdy and well made. More pics and updates to come.
care to guess approximately how much weight this puts back there? did you ever replace your springs? wondering if these affect handling at all.
The hitchgate itself is about 60 lbs. Then you account for the spare being a little farther back and Im thinking it's roughly 100 lbs more than usual. My Sway-a-way 1.5" springs arrive Monday and get installed Wednesday to balance it out.
1.5" Sway-a-way rear coils installed. Front bilsteins set to 1.75". I left a 10mm OME trim packer on the drivers side to fix the lean. The springs will settle down a bit hopefully but I am pretty pleased with the stance and it rides great. If the rear doesn't settle much I may think about going to 2.5" on the front bilsteins. I like the rake, what do you guys think?
Also, I found the springs on amazon: aFe Power 102-1650-195 Control Sway-A-Way Rear Coil Springs https://www.amazon.com/dp/B01BSESRFG ref=cm_sw_r_cp_apip_eJtARxG6lTT62
lindwlson982
