HaydenATX's '15 TE-The Yeti
Coil spacers, as it's sounding like you're not getting the forward rake you need.
For sure. Ya I'm trying to decide if another 1.25" in the back might be too much. I ordered the SAW 1.5" rear coils that are stiffer and will handle weight a little better but I'm afraid it might be too high... I'll probably still do it and hope I don't look like a dragster.
Do you carry gear in the back on trips? Or tow? It's better to have some forward rake and then it level out when on trips.
Definitely have it in the truck. Eventually I'll get a trailer but that'll be years. I think the SAW coils will be perfect
Swapped the rear valence and plasti dipped the badges to match the pro grill. Shout out to [MENTION=127657]codyHTX[/MENTION] for the help
Do you have a link to where you got the platidip in this color? I would like to do the same to have the back match the front
Awesome build! Maybe I missed it but which Shrockworks sliders did you order? Did you call them or order online? What did you tell them exactly? It seems they have different pictures on their website and no difference in the order section. I like how flat yours are and how they can be used as a step. Thanks.
Thank ya. They are textured black powdercoat with dimple plates. I ordered them via email because we worked out a product trade... If I were you I would call them and they will make sure to get you the ones you want.
so do you actually work for....them...? being obtuse on purpose.
Finally got around to cleaning my trd wheels after a year of not taking care of them. I used to use that stupid armor all tire wet and it left a gross residue on my tires and wheels. Bought some wheel cleaner and tire cleaner from Adams polishes and they did a killer job.
before
after
Installed Rigid Dually ditch lights and CBI brackets. I wired them directly to the battery and to the included switch. For some reason I can't get them to light. Anyone have an idea? Blown fuse?
It may sound weird but some of the LED's i have installed you need to swap the wires (black on the positive and red on negative). I am not sure if the dually's are like this. I can't remember but if not I would double check your connections at the switch.
Thanks for the tip! I have heard of this too.
Just tried it and still nothing unfortunately.
Do you have a multimeter?
Unplug the light and see if you're getting power to the plug. If not, trace back to the relay.
Update: I forgot I had ordered another harness by mistake. Swapped the fuses and boom! Also the polarity is definitely reversed.
Jhunt
