Does this beam pattern look normal? The light lines just above th red throw me off but maybe thats a normal pattern on these rigs...anyone elses look like this? Not the greatest pic but I hope someone can tell what I'm talking about.
yeah mine kinda do the same. they jump up to the right on each one.
My 4runner is locked up in the garage right now but I've noticed that on some other vehicles and the only sense i can make of it is that it keeps the beam from going into the oncoming traffic and at the same time lighting up the right side (curb side) to light up street signs and a better view off to the right...
I could be way off but it's the only logic i could come up with
It's a perfect beam pattern. If you were in the UK, the slope would be the other way.
A bit off topic, but does anyone have a perspective on the beam quality of a 96-98 4runner compared to a 99+.
I am very disappointed with the low beam headlight in my 97, and considering swapping to 99+ lenses and a LED plug & play kit like OPT7.... But I am unsure if that's what I really need to be looking at doing.
My 96' has one original headlight casing and one new casing.... both lenses are not faded from the sun but the inside chrome is nowhere near the quality of the newer side and it definitely shows in the quality of the light output. I will someday replace the older one but definitely a very big difference
Nice, so the newer side is a 99+? I'm thinking about rolling the dice on the Depo 99+ headlamp assembly and the OPT7 LED kit. It can't be worse than what I have. I outdrive the head lights at about 50-60mph in dark areas.
Well, I was pretty disappointed with the beam strength with stock lights on my 98.
I didn't want to do a HID conversion, so I opted for the easiest way, changing out the bulbs.
I use those, much brighter than stock, and the advantage is that they have a long lifetime compared to most high illumination bulbs. Kinda expensive though, those are canadian dollars. My daytime running lights are now as bright as the old normal night setting with the stock ageing bulbs.
https://www.amazon.ca/gp/product/B00544ZD86/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Thank You very much... the link you supplied doesn't fit a 3rd gen 4runner but i will just figure out the swap over numberthe ones I posted are 3600K, which is a yellowish white, not a white-white.
