Headlight Retrofit '03-'05
Not to hijack. I got an email back from TRS about the FX R Bi. with the 3five bulb and shroud came $200 out the door. Standard low beam with an RX or TSX is $275. What's everyone opinion on the FX R? I already have the PNP HID which is somewhat getting attention from other drivers. I did lower it a bit but I still occasionally get flashed. Light output is phenomenal with no hotspot and much wider than stock. I don't want to aim any lower as it takes away the purpose. So I want a projector but not go overkill on it.
Thanks!!!!
If I would re-do my retrofit all over I definitely go Bi-xenon. FX-R is a great projector. I'm not sure why TSX are so overpriced. I paid $120 for my set 5 years ago. The reason I chose them is because they were cheap. Price doubled since then? Wow. Probably demand is high since they very compact and easy to install. TSX is ok projector but there is so many better ones out there. TL, LS460, FX-R just to name a few.
First response and I'm good to go...Hehe. never done something like this before. Thanks!!!:usa2:
Encounter my first hurdle, need to do so dremel trimming for the HID reflector to be expose more.
As Far as opening the housing, it was very easy. It just takes time and patience but it was easily than I thought it would be. 265 degrees for 7 minutes, it was perfect.
Can't wait to get mines. I ordered the FXR. Did you get the 3five bulb or their newer version XB35?
XB35, when spending over $270, what is an extra $20 you know
Yea extra $20 for something better no big deal. The XB was back ordered for me so hopefully I don't have to wait too long for it. Or maybe shoot for the Phillips for an extra $45 instead of the $10 for XB. Gotta give them a call or email now since we're chatting. LOL
Here's my QUAD Bi-Xenon version 1.0
Linky to the build, http://www.toyota-4runner.org/4th-gen-t4rs/157515-another-projector-retrofit.html
20131227_142824_zps5b00925b.jpg~original
[/URL]
20131227_142819_zpsaed08b5c.jpg~original
[/URL]
20131227_155754_zps4165005c.jpg~original
[/URL]
Here's My Quad version 2.0
Linky to this redo.
http://www.toyota-4runner.org/4th-g...projector-retrofit-part-duex.html#post1613621
IMG_2943_zps8171e996.jpg~original
IMG_2936_zpsa96d447b.jpg~original
IMG_2934_zps51e3490a.jpg~original
i did a few more, one on a 13 5th gen and one on a 14 mini cooper countryman. have one more project for a 13 5th gen in the works.
[/URL]
[/URL]
[/URL]
Linky to this redo.
look awesome and thanks for the link. Can't wait to get started on mine.
Here's a link to my Acura TL retrofit. They are great but take a lot of precision to fit and align because of their size. You won't have nearly as much trouble with the FX-R's.
Good for you for getting an extra set of lights. Put those in the car while you cut the retrofit so you're not rushed to finish. It's a long process, but well worth the output.
Very Nice...thanks gona need all the help I can Get. My drill and I Are Still Not on Speaking terms. I believe I paid $100 for the 2 Sets of headlights. I Paid $60 for 1 set a while back that look New. Then I found these for $40 that look very Good too. Both OEM which is what I wanted. Ya I want to Take my time with this project. Now time to look at my lighting options Thanks everyone for there input makes this much easier.
I am Debating the Retrofit Mod or 06-09 Headlight Upgrade. Having a hard time deciding as the 06-09 headlight look is Very Sweet as well.
I'll second the TL retrofit! LOL. Anyway, the TLs are freaking epic. The 06-09 projectors are sweet, but a retrofit can/will blow it out of the water.
DSC09802.jpg~original
I'm also wondering if it would be easier to just buy the 06+ headlights to start with them get the retro source kit designed for the OEM housings? Seems like a decent setup.
Im going back and forth. About a year ago I bought all parts needed for a 03-05 retrofit. Got everything in and buttoned up, but had MANY problems (my own doing, of course). I couldn't get the darn headlights to reseal correctly and I also was having such a hard time correctly aiming the projectors. Every time I thought I had it right I would test drive and I would get flashed by oncoming traffic.
Also, possibly from the aftermarket Depo headlights I used the front plastic showed stress or heat? cracks right in front of the projector.
Sadly I scrapped the build and went back to the terrible stock and foggy reflectors. Been saving to get the 06-09 OEM Sports instead.
I still have all the parts, in case I rally up the courage to try again though.
Retrofitting is hard work, I just wasn't versed enough for the job :/
I really like the updated look the 06-09 Lights. There are ways to Ugrade the 06-09 for better output I assume. I am going to get a Front Bumper so I wouldnt mind bringing the Turn Signals up. Just like the Look that's all. :redbrick:
Realize when you do that, your side body cladding will no longer match. This is why most don't "upgrade" the front and rear bumpers to 06-09 models.
