Headlight switch problem
I've got an '88 SR5 and the switch inside the steering column broke that changes the headlights from low to high. So now the default setting is high beams, unless I hold the headlights arm on low. I'm having trouble sourcing a new one online, can anyone help me find one please?
Had the same problem on my 85, turned out to be a bad solder joint on the back of the switch. Resolder it and you'll be good to go.
seltzernator
