MN4runnerman
Senior Member
Preliminary info: 1999 3.4l Manual SR5 Non DRL 100% Badass
So after doing some trail riding yesterday in the heat it wouldn’t be a fun weekend if something didn’t go wrong. First issue: The ABS light is on. things I checked, brake lights work, brake fluid is full, speedometer is working without issues. Not sure what’s up with this one and I believe it to be unrelated to the rest of the problems. I need to borrow a scan tool that does ABS(mine doesn’t) and see if I can diagnose further. But if you have some ideas throw them out there. It’d be greatly appreciated. Second and third issues are probably related to each other. The headlight fuse blew and turn signals quit working on my drive home from the trails yesterday afternoon. I broke an aftermarket turn signal I wired in when a tree magically appeared in front of my truck while navigating an obstacle. The turn signal light broke but I zip tied the pigtail up out of the(it could’ve come in contact with something and blew the fuse). I don’t think there is an issue with wiring because I used weatherproof butt connectors with heat shrink over that and conduit with heat shrink on the ends over the wires. The headlight fuses both are blown and the third 10a fuse(the one a couple spots down from 10a headlight fuses)which I can’t remember what it’s for is also blown. Haven’t checked interior panel yet it’s just too hot to do this tedious crap. I need to diagnose further I was just wondering if anyone ran into issues like this. Found some old threads but the info didn’t seem too relevant and the one I did find didn’t have the fix posted.
Thanks!
Here’s an obligatory picture too, you can see which turn signal I broke. :whipping2
Thanks!
