Heater hose lines off of the water pump?
Hi, i am wanting to install a circulating tank heater from kats and can not see the hoses that run to the heater core. usually one would see two hose lines running up the passenger side of the engine compartment. not seeing them. anyone know where they are routed?
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200339137_200339137
What engine do you have?
They are both pretty short........If you have the 5VZ they run from almost the center of the firewall to the back of the engine.
Edit: Here is a basic pic of them.....
http://www.ncttora.com/fsm/1996/SIL...pdf/02rmsour/2002/024runne/ac/heauni/remo.pdf
If your runner is sporting a V6 the heater hoses come off the back of the engine. One line has a valve in it to control flow of coolant through the heater core. Located at firewall almost right behind the throttle body.
