Heater water valve left me stuck!
bwallick
Junior Member
I bought a 2000 SR5 with high mileage and spent a lot of money, time and effort to make it reliable. Everything from seals and bearings to a diff breather. I read all the threads about problem areas and thought it was near-bulletproof after all my work. But the other day one of the nipples broke off the heater water valve on the firewall and dumped all my coolant. I had lots of water and tried to limp home, but eventually it overheated, started pinging and gave me a CEL. I was only 34 miles from home but the tow still cost me almost $500. And now the engine is pumping bubbles out the radiator and the coolant is contaminated. I'm working to pull the heads and hopefully there are no cracks. This could really get expensive due to machining possible head warpage, or cracks requiring replacement heads.
So I want to share my story so that others will not be caught out by this defect in waiting. The valve body is plastic and it will break at some point. Mine just disintegrated. With a pressurized system it's hard to plug. I should have just stopped, but better yet, I should have just replaced the darn thing when I was doing everything else.
  • Like
Reactions: BTO
This is a known "it will break its plastic and hot coolant issue" So keeping a spare or a 1/2 nipple to join the lines is a good idea so you can drive home, or just wait for the tow truck to avoid engine damage.
  • Like
Reactions: BTO
For anyone who cares, this is a $110 part or so, 87240-35070. It takes 20 minutes to change, you need a 10mm and a pair of pliers.
Sadly these are a week spot. Originals ones really should be replaced. If you see a seep of coolant coming out of the bottom replace it. Slightly turning brown replace it. Also try to keep in eye on it if yours have never been replaced. Nothing wrong with keeping a new in inventory. Be very careful with the aftermarket ones, they don't last... :-(
Maybe the valve's lifespan can be increased by better securing the hose that connects to that nipple?
No, the factory constant tension spring clamps are high quality and reliable. The valve is made from the same material as the OEM radiator end tanks - which also needs to be replaced every 15-20 years...
-Charlie
-Charlie
I was meaning securing the length of the hose from vibrating or moving around. Not the connection to the nipple. Maybe some kind of stress relief attached to the firewall?
It's the heat and heat cycles that kill it. I have found few issues with vibration affecting wires and hoses in Toyota engine compartments in 28 years of owning Toyota trucks. Other manufacturers may not do as well. You can sometimes zip-tie nearby wires/hoses to a nearby part of the engine or to each other for some extra "bracing" if it's a concern. Do check that you are not causing extra wear between parts by doing so.
There is a lot of possible movement between the engine and the body, both the body mounts and engine mounts move. The hose to the engine needs to be free to move.
-Charlie
This just happened to my dad's sequoia. Left us stranded up on a mountain in Tahoe. Drained all his coolant and overheated the engine bad, you could hear the valves chattering, sounded like you dropped a handful of marbles in his motor. Got it towed home, replaced the valve, refilled coolant and she's still running like a top with 310k+ miles on the old girl.
Yet another reason to use Torque Pro or a similar app, cause he said his temp gauge didn't move much, then it just pegged all the way high.
youngrk
