HEAVIEST load towed with 4Runner
Again, I would not (as many on here have echoed) recommend using a WDH on a crossmember mounted hitch (factory 5th gen) you'll just end up bending your crossmember or worse.
But the one you bought clearly says 7300 lbs IF YOU USE A WDH, since you're not using a WDH why go through all the trouble?
And where does it say not to use one for 5th get? It's not impossible for the engineers to consider that moment force when designing the cross member and that's why they don't say not to do it on the owners manual like they did on the 4th gen.
But my main point is still the first thing, why go through the trouble if you aren't using a WDH?
Sent from my HTC6525LVW using Tapatalk
Short drive in town to prep for trip with big rig.
Again, if you had read, the hitch has a NON-WDH rating of 6000lbs. 7300 WITH A WDH -- same as your magical 4th gen you keep referencing....
Right off the bat you gain 1000lbs of towing capacity, in theory
There is no where it says explicitly that you can't use it, but technically its not designed specifically for a 5th gen nor is it represented as an option from the dealer, so that being said, its technically not legal if you get into an accident or get pulled over for an unsafe load...this will rely on your intuition and experience to know what is safe and what is not safe so you stay out of that situation...
Further than that, to your last comment, its far more robust of a design over the stock cross member unit. More attachment points, more load distribution, more steel. Instead of just distributing the weight on a far less substantial single point on a section of steel welded between the frame rails, it mounts directly to the frame rails and provides a much better distribution of weight by design to the front and rear suspension (THIS IS A DIFFERENT STATEMENT THAN USING A WEIGHT DISTRIBUTING HITCH) where as the stock unit can only really distribute the weight to the rear of the suspension
Lastly...just because I am not using a WDH now, which is an attachment to the hitch not necessarily a stand alone unit (duh), doesnt mean I wont retrofit it later...
2017 Coachmen RV Apex Ultra-Lite 300BHS
And I rented it for a long weekend and dragged it about 300 miles.
How did it do? My wife and I are talking about getting a 22' Vintage Cruiser and it weighs about 3200 dry. I just wanted to make sure I wouldn't kill the new 4runner. I know the 4Runner will tow "5,000lbs"...I just wanted some info from a real person instead of a book.
I drag a 3500 lb boat all over eastern NC and haven't hurt the truck at all. With a camper, because it's like having a large sail behind you, I would put airbags over the rear axle for stability.
I have towed a 20ft open trailer with toys and total weight is around 5k. My estimates are as follows:
trailer: 1500lbs
teryx fully caged with 4 seat: 2500lbs (high side)
Raptor 700: 500lbs
Trailerblazer:400lbs
Total weight: 4900Lbs plus some gear, spare tire I am at max.
I am in So Cal and have hills so manual shifting is a must. Going up the Cahone pass on the 15 im in 2nd at 40mph. It trucks right along but not fast. It did well but its not a tow rig. I am on the fence about airbags and tranny cooler or buy a dedicated toy hauler. If I continue than airbags and tranny cooler I feel are a must.
trailer: 1500lbs
Raptor 700: 500lbs
Thanks for the input...We are planning some pretty longs trips if we go ahead with the purchase, so I think I will look into the airbags
Max Load
I'm hoping that my 2011 can haul 4,800lbs for a road trip down HWY101. I'm having air bags installed in the rear suspension, my tow hitch upgraded to class III, a tranny cooler installed and a ScanGauge II to monitor temp. Sway bars are also being installed. I know that none of this actually increases the towing capacity but I'm hoping it makes it possible and as safe as I can make it.
I have 20 foot box trailer that weights between 5500/6000 lbs
What would y'all think about using a 4runner just to move it from storage to my home about 2 miles away ?
all flat ground?
it'll tow it just fine, just slow and steady, leave lots of room for braking (even more so if it doesnt have a brake controller)
I have a 8.5x20' with the mods I mentioned earlier, and loaded up at 7k it tows fine.
It'll do it just fine, especially with all of those mods.
I towed a 8.5x20' from phoenix, az to dublin, ca. It was empty, had 10k axles and was about 3800lbs tare, did it just fine, without the trans cooler (I towed it back in march at night)
I am looking to move about 1000 miles away here soon. I need to tow a '99 Jeep Wrangler with a few mods to it and a bunch of stuff from my apartment. The Jeep weighs in at 3500# and I am going to rent a U-haul car hauling trailer.
Has anybody towed this much? If so any recommendations?
Yep, I have a few times. It'll do it fine. I installed a trans cooler and airbags ahead of time, the uhaul trailers are tongue heavy as you can't have the car sitting back.
Monitor your trans temp, leave it in S4 and expect 11-12mpg. Drive with some brains and you'll be fine.
