Help!! Bug spray
jake0713
I just bought an '04 runner a couple days ago and already I have messed it up.
I sprayed bug repellent on my arms while working on my other car. I jumped into my 4runner and rested my arm on the center console. I looked down immediately and noticed a major discoloration. It was like it had a horrible chemical reaction.
I tried rubbing it out but it seems to grip the towel...
Has this happened to anyone? If so, can it be fixed?
That was not a fun first post! Welcome to the board, but wish it was under better circumstances.
I don't recall anyone posting a similar problem. Closest that comes to mind was the issue of using Windex on the dash (don't do it).
Have you tried anything to clean it -- that maybe instead of a discoloration that it's residue instead? If it was a discoloration, I'd suspect that some of the color was transferred to your arm. From your description that doesn't seem to have happened.
I'd start with water, then work to progressively stronger cleaners -- stuff like Meguiar's (or comparable) cleaners, perhaps Simple Green. But test in an inconspicuous place first -- you don't want to make it worse.
If it's just the console cover, then you should be able to replace it. But try cleaning it first.
Good luck and keep us posted.
