HELP! Busted transmission line
Rustysurfer728
So I got home the other day, noticed I was runnin a little warm. She turned off a little different than normal, then I get out to look under the hood and my coolant and transmission fluid are pouring out. Awesome.... I found the line that popped off that's connected to the radiator... Not sure where to start as far as parts and ideas as to what the cause was... any help is beyond appreciated. Cheers
Pull your dipstick out and make sure its still just red trans fluid.
If you had trans fluid and coolant pouring out I think its time for a new rad.
Make sure you didn't get coolent mixed with the trans fluid.
Yeah, if you've got coolant coming out of where your trans line connected, that's pink milkshake time! Get your trans flushed ASAP if that is the case, the longer that coolant is in there, the worse off you will be.
Did the rubber hose just disconnect from the rad? Just replace the hoses and clamps. Easy peasy
If he's got coolant and trans fluid coming out of 1 line that disconnected, he should NOT just reconnect the lines!!!!!!!!!!!!!!!!!!!!!!!!
I understand that which is why I was asking for more info, but if he could identify both fluids separately "my coolant and transmission fluid are pouring out" then he does not have radiator breach. Unless the fluids were pouring out from opposite ends.
Deno91
