Help, Car apart and I'm stuck, IAC problems!
Markjr
Ok is it just me or does it look impossible to remove the Idle Air Control valve. I have to stick a screw driver into a little more than a 1 inch gap to get it off and Im pretty sure they dont make screw drivers that small, even the stubby ones. What am I supposed to do? My car is apart in the driveway and I cant seem to figure this out.
I just removed mine and it was stuck on there. Put TB in Vise. Remove the 4 Philips screws that hold the IAC on. Use a flat blade screw driver and pry IAC off TB. You will likely destroy the o-ring gasket that is in between the IAC and the TB. Make sure you have a new gasket before disassemble.
Thanks for the input, I have gotten much farther. I took the throttle body off, flipped it over, hammered a 5/16 socket onto the screws and they piratically slipped right off with the ratchet :) I want to do a DIY when I'm finished on how to do this.
Yeah I service the IAC every year. I am surprised some people don't have to.
After your first time, you'll be able to do it within an hour. I would recommend spending a lot of time on those brass cheese head screws though. They strip really really really easy. Like you, I stripped them the first time and had to pound a socket on them. ;)
Here's a semi-good writeup on it, but nothing great.
Re: 3.4L V6 Hard Start "hot" Cleaned IAC (Pics) - YotaTech Forums
This is what i do for stubborn phillips screws, I use an old motorcycle trick. I place phillip screw driver on top of screw, while applying a little tension counter clockwise, I hit the handle of the end of the screwdriver with a hammer and the shock breaks the screw loose.
Works 98% of the time.
Gee,when I learned it it was an old farmer trick for working on tractors.
I'm 12 years and 132,000 miles without touching my IAC. Idles right at 750-800 and starts like it had ether in the engine. I'll clean it if I have to, but meanwhile I'll leave well enough alone. I certainly am not looking forward to getting those screws out.
delislerebecca
