Help diagnose this front end noise??
DaddyLongToes
I am trying to figure out what noise is coming from my 4R when I make a right turn at slow speeds close to full lock. Mostly at a red light taking a sharp right or pulling into a parking spot.
I’ve looked for any indications of rubbing, greased steering stops and also trimmed some of the inside fender to see if that was the issue and the problem still continues.
Here is a video from the inside of the 4R and the noise starts at 11 seconds.
https://imgur.com/a/gmkDcLo
stock? leveled? stock control arms? shocks oem rubber style or rod bearing style like fox/king use? KDSS? was it the clunk at the end of the video? or was that the blinker turning off?
check the UCA through bolt. if its loose it could clunk. Are your LCA's torqued properly? if the KDSS sway bar attachment to the LCA is loose itll also clunk.
AndiGarage
