Help finding voltmeter/USB charger that fits into switch blank
e60ral
Banned
I am looking for a voltmeter and usb charger with matching switch that fits into the switch blanks in the center console, ideally like this with the protector for the USB socket
Where should I be looking, so far i'm not having luck on google or amazon or AOB. CH4X4 has one but the voltmeter is only 2 digits, it doesn't show tenths.
For switches from CH4x4, does anyone know if I need regular or small push switches?
I would settle for a separate switch + voltmeter + usb charger setup if someone knows a voltmeter that fits
EDIT- Nevermind, per the reviews these switches below also only show the nearest full volt:
Does anyone know if I would need this one or this one, both say toyota but the one that says 4runner 2010+ looks wrong:
(I assume this is 5th gen related since i am looking for something that fits into the 5th gen switch blank specifically)
"...I am looking for a voltmeter and usb charger with matching switch that fits into the switch blanks in the center console..."
Hi e60ral,
I think this may be what you're looking for(?)! Made by AOB fits late model 4Runner (5'th gen) 2.0 usb hub, 5V car 'phone charger' "See below":
Power Outlet 12V DUAL USB 9 CAR Port CHARGER 5V 2.1A TOYOTA 4Runner Yaris | eBay ...as far as the volt meter, they range in price and can be found on ebay; just describe what you're looking for in ebay's search field and select the one that you need. 'Hope this helps'
rig, cheers!
Thanks. So it looks like the small switches are correct. The voltmeter is the real problem, maybe I'll take a chance on the amazon ones I found with mixed reviews
Sent from my SM-G930V using Tapatalk
Does Amazon one (looks like the 1st link by OP is correct one) fit into the punch out that the USB/AUX ports are (next to cig lighter)?
And has anyone relocated their USB/AUX ports? I don't find myself using the USB/AUD port at all, would be nice to move them to glovebox or something and in place put the voltmeter there.
There have been a few people who relocate them to the glovebox but I can't remember what build thread had the info
charlesz
