Help I need tools Sockets numbers
hgarcia
Help I need tools Sockets numbers (metric) for Emergency repair
I have 1999 4Runner 4cyl numbers (metric) because I need it for in case of Emergency like Water Pump, Serpentine Belts, EGR, starter, other most useful components to repair middle of road going to Mexico that's why plz reply I have no tools.
If you have a 6cyl give me an idea
Thank You.
10, 12, 14, 17, 19, 21, 24(differential fill and drain)
Add 8, 9, 15, 16, maybe 22 and whatever Allen hex head that the recessed front diff fill and drain use...12mm?
Replacing a water pump in the middle of the road is a pretty big job. It'll require pulling the front engine covers off. I'm not sure if it's possible to do it without removing the fan and accessory belts too. You will definitely need to drain the coolant, either disposing of it properly or replacing with a new mixture. If the fan needs to come off, you should have a set of ratcheting wrenches or one size at least (either 12mm or 14mm). For the rest of the job, it can be done with a 3/8" drive ratchet and sockets (10, 12, and 14mm) with a 6" extension.
Something like this kit from Tekton would be a good place to start. But, the description of it on the page is not accurate. It does not include 1/4" sockets. You don't really need them.
Also, replacing the starter is a huge job, not to be handled on the roadside. If you are replacing the starter contacts, that is a job that could be done roadside, but there should be some lead-up to the starter failing.
Take a look at some threads where people list the items they carry for roadside repairs or off-road repairs. I'm putting together a list of all that I carry in my build thread, specifically HERE. I just started it, but I will open all my bags and boxes to show what I think is useful.
Good luck.
*Edit: Oops, I reread your post. I was referring to those jobs on the V6. I see you have the 4-cyl. Either way, the Tekton kit that I linked to is a good start to a basic kit.
Someone correct me if I'm wrong... the 1996-98 use a 14mm hex for the front diff drain plug. For 1999-2002 it was changed to a 10mm hex.
The fill plug for all years uses a 10mm hex.
Laredotx
