Help me identify this coolant hose!
sc-4runner
I noticed this hose had a pinhole leak and was leaking drops of coolant. I know its the coolant hose to the throttle body but I can't seem to find the part number. I have searched the site and the internet but had no luck. So someone out there help me with the part number to this hose! :thanks:
DSCF8873.jpg~original
If it's a simple coolant hose just pull it off and get the length and then go to an autoparts store and buy a similar length hose with some hose clamps...problem solved.
Not like toyota hoses are better than normal hoses ;)
I don't know if I agree with that. These hose have specific bends Also if you are going to get a hose why risk some aftermarket part for such a small part yet crucial piece.
Thanks for the replies...
Yea I thought about getting the hose from an autoparts store but it does have a bend to it
any others know?
I do not know the part number but I replaced all those small hoses when I did my timing belt. From Toyota they were only around $6 each. Get the Toyota hoses. They all have custom bends and slide right into place without any hassle. Some of the online Toyota parts places used to have a parts diagram but Toyota made them take the diagrams down. This makes it harder to find the part number. The Toyota dealer parts guy would have them and could easily find the correct hose. I doubt he would stock it though. It would have to be ordered. If your hose is leaking near the end you may be able to cut the leaking end off and reattach it.
The house is pre molded, most of those hoses these days route through tight spaces and such, so a non molded house tends to kink.
any others know?
do you live very far from a Toyota Dealer? if not, then drive out there and get the right part. I think you are making this more complicated than need be. A part like that, you dont want to cheap out on, besides it cant be that expensive.
Simply stated. Go to the dealership and have them look it up for you and buy it there. That's it.
Why would he need to go anywhere when I posted the exact page that the dealer uses to look it up? Not to mention it would be cheaper buying it on line?
Opps didn't see that . Thanks for that link Sungod. I am going to bookmark that. I could really use that too.
