Help me with rubbing...
08t4rlimited
I installed 275/65/18 and there wasn't "supposed" to be any rubbing.
Hard wheel turns and minor turns in reverse seem to rub on the inside lower wheel wells (the thin plastic) and the upper control arm (I think that is what it is called)
I found a DIY for moving the plastic liner but what about the control arm? I have a daystar 2.5/1.5 lift.
Wheel spacers?? Please help I am having trouble driving without reverse and only taking wide turns...
I installed 275/65/18 and there wasn't "supposed" to be any rubbing..
What Toyota Guru told you that?
I guess you want to keep the larger tires, so what are your choices?
Wheel spacers and /or a Body Lift comes to mind. A wheel spacer would help eliminate some inner suspension/frame rub, keep in mind anything more that 3/8" or so is a wheel adapter when shopping for one.
A BL will also get you some more room in the wheel well for a larger tire.
Other members on here and Tire Rack....anyway what size wheel spacers do you think?
7ron
