HELP! Need Various Pics of Intake Manifold Hose Hookup
K_Labs
Member
I have a 1990 4runner. I have recently done a motor swap and I can't remember where some things go.... I had taken pictures of this but my dad deleted them off the digital camera because he needed room. Now I don't know where the hoses go on the passenger side of the intake manifold. Please post me some clear pics of this or refer me to the correct page of the owners manual so I can finish this many more questions to come. Also there is a ground wire that attaches to the inner driver side fender well. I have no idea where that goes.<<< I can take pics of it so you can get a better idea of what I am talking about.
BUMP....
Ok maybe not various pics.... Any pics would help. I have most of the lines figured out. There are a few that confusing and there is 1 extra hose fitting
Thanks for the effort! I've been flippin through this service manual for like 15 mins..... Did I forget to mention 3VZ<<< Sorry!
IMA BIG DUMMY!
I was looking in the wrong book. I needed the first one and I was looking in the second one. I found it all on page EC-19 WOOOT!
4Cyl or V6?
I won't be much help, all my hoses are disconnected right now, as I'm *trying* to remove my intake chamber...
V6 and I just set up a photobucket account so I can post pics. Pics coming soon. Sorry Ima posting mad man
P1010011.jpg~original
P1010010.jpg~original
P1010009.jpg~original
P1010008.jpg~original
P1010007.jpg~original
P1010006.jpg~original
First 3 images are the mystery ground wire that I don't know where it goes. It is located next to the coil.
Last 3 images are the 6 fittings that I don't know what hooks up to them.
Give me full specs of ur car, I have a book that I believe has ur engine in it too. I can look it up. Vacuum hoses right?
Edit: Dang my book only goes from years 70-88 it doesnt have 90 lol
I am looking at a 1988 3VZ-E vacuum diagram and are those on the left side of the motor?
Anyways what i think from looking at diagram they may lead to "AS, FPU, EGR, VSV" whatever those are.
Also maybe a "AS Reed Valve" and maybe "EGR Valve" and a "check valve" that they may connect to also...
Sorry IM probably no help
That looks like an engine ground wire that goes to any bolt that goes into metal on the engine. The other device that's tied into it looks like a large capacitor .47/250volt If anyone has a wiring diagram for this year T4R it will show it.
den said:
That is the same exact page I found last night. But in my book it is EC-19 I have the toyota service manual from the dealership.
As far the mystery ground I think I remember it going somewhere on the engine. So anyplace on the block is fine. Obiviously not on the heads as those are aluminum.
Hey den I couldn't get this link to work http://toyota.japancats.ru/details....reg=U&piid=6841
Yes that is the left side of the Intake Manifold Near the back if u look closely you can see a fuel line hookup and sorry I had to crop the pics to upload on photobucket. Specs on the car are 1990 T4R 4x4 SR5 V6 3VZ it's a 1994 motor but I switched to the 1990 intake to make it easier to pass smog.
У нашего провайдера существует разограничение на российский/зарубежный трафик.
К сожалению для IP 71.103.14.167 доступ закрыт.
"Российским" считается трафик от любого объекта сети, IP-адрес которого попадает в список "российских" IP-сетей провайдера.
Список IP-адресов стран СНГ обновляется из публикуемых списков IP-адресов соответствующих стран.
Проверить принадлежность вашего IP вы можете по базе WHOIS RIPE NCC
this is what I'm gettting
Any idea where 17341E hoses come from... They are just laying on the ground... LOL when I figure those 2 hoses I'm done. The rest I can figure out based on that pic u gave me. Thanks Den You rock
Wow thanks again den! I contacted a fellow forum member and I am going over to his house to see how the rest of the hoses are hooked up. So I can stop wasting every1 else's time. :)
