help on swapping diffs
isu2014
Hello,
I'm going to be swapping my diffs from 4.10 to 4.56. I can get my hands on a 2nd gen 3rd member already detroit locked and 4.56. I'm not sure if it's a 4cyl or 6cyl (I have a 3.4l open diff), or does it even matter?
If my research is correct, the 3rd fits but I need a pinion flange adapter for 30 to 27 spline. Is this correct? Is this all I need? Am I on the right path here? Or should I hold out for a 4.56 e locked axle?
Please help a new guy out.
I'd get an elocker. I've had detroits and really dislike them on the street. Makes the driveline feel sloppy and clunky. I would think all 4runner thirds have the same flange bolt pattern, or you can get the double drilled flange.
The problem I'm running into is the e locker is hard to find in a 4.56 and I would like to buy the whole axle already set up. The salvage yards have them listed wrong and all the "4.56" axles are really 4.30. I could start with 4.30 but I would like to do it right the first time.
I have a 5 speed 3.4l and I will be running 255/85r16 KM2s with 3.5" lift and plate bumpers, full skids, rock sliders, and the usual junk.
Toyota 8" V6/Turbo/E-Locker Gears, Install Kits, Carriers, Spider Gears - Precision, Yukon, Motive, Lockright, ARB
Why not purchase an elocker assembly?
That doesn't include the e locker motor or wiring and I would need to modify the housing of my current axle. I would buy an ARB for that hassle.
But anyway I found an e locker axle with 4.30 gears for $100 that I'm going to look at next week. It would fit the bill for a while and I could upgrade to 4.56 cheaper and easier.
2nd Gen diff should drop in if it's a V6, I just put a V6 3rd Gen Pickup diff in my rear end with 4.88's, no swapping necessary, just dropped out my third and bolted the other in. Not sure if the locker changes anything.
FoxyMama
