Help, transmission
JBend
So, I posted a few days ago about my transmission issue after I picked up my car from the dealership. Let me run you through the history.
Bought the car on 4/20/20, I've had ZERO problems with this car, ran like butter, other than the seized calipers which were replaced immediately with a power stop z36 brake kit. Had the usual OBD sensor problem, VSC light traction control Tom's, check engine. Runs smooth and had my mechanic check the chain AND the dealership that it's at right now, no problems.
Took the car in to make sure my AC was going out and didn't need a charge, changed the fuse to check that before I dropped it off, no Bueno. AC is bad. Next day I pick it up because, one, not paying $1200 for AC, two, don't need it right now. They also mention I now have a radiator leak. ZERO fluids have shown up under the car in the year I've had it. Nothing. Fine, I'll buy the parts, replace it and do a flush myself, no problem.
NEXT DAY, after picking it up my transmission is upping from first to second. Gradually gets worse. Now I've got 3 options according to the dealer....
1.) Transmission flush and change
2.) Drop the transmission pan and check for metal shavings with a full flush and change.
3.) New transmission...
My thoughts off the research I've done on here and elsewhere.
Get them to do the flush, AAA it back to my place and do the radiator in hopes it's fine.
I think and have good faith I'll be ok after this.
I need your alls much more educated and experience thoughts on this. I trust you all, more than I trust the dealership.
Thanks,
And sorry for the 10,000 word diary entry.
Help me save my baby I have $3k worth of parts on my desk waiting to be installed
:noidea:
Maybe I'm just tired but I think this is the only transmission symptom presented in your post.
You're going to have to be more specific and/or post a video of the problem to get useful feedback. The A750F doesn't have many problems... but when it does have a problem it's a real bugger to fix.
EDIT: Slipping? Slipping from first to second?
:noidea:
yes sorry, not upping. It started to slip bad and is at the dealer. They're doing a drain and refill then I'm having it towed back to my place to change the radiator. Hopefully she isn't dead. There is am 06 dbl cab tundra near me with 88k miles on it though....one owner....
Sorry to hear about all that. Im trying to tie everything together. Certainly, the AC and radiator can go together if the AC clutch/ compressor grinds and metal gets in the radiator.
Sometimes a bad radiator can affect the transmission cooling process. Im not sure if that happens in the 4r or not, but hot transmission will damage it
? how can the AC compressor get metal in the radiator??
^^ I'm with this guy.... you're gonna have to elaborate on the AC grinding and getting metal into the radiator...
My rad was weeping from the seam between the core and the caps. Coolant would seep out while the system is hot and pressurized, but then evaporate on the hot rad without actually leaking onto the ground. And without the heat (expansion of components) and pressure (pushing the water out), it was fine.
Anyway, the red stains on the outside was the giveaway... but I never would have seen it from standing infront of the truck. For me, it was cheap insurance to replace it to make sure it doesn't explode at the worst possible time. Replaced the main hoses too just to be sure.
Overkill? yeah... probably. Anything worth doing is worth overdoing, right?
07 178k miles
V6 or V8?
Did you take off the Transmission oil cooler? If so, you might have introduced dirt or trash into the system. Doesn't take much to stop up a ball in the valve body or a screen somewhere.
Just realized you haven't done the radiator yet....
Put some lubeguard in it. Can't hurt and it just might fix it if something is sticking.
Amazon.com: Lubegard 19610 Dr. Tranny Instant Shudder Fixx 2 Ounce 2 Pack: Automotive
lubegard is for shudder, not slipping. & based on the details in the post he didnt do anything, just picked it up from the shop that checked the a/c.
V6 or V8?
Lubeguard is a friction modifier. Slipping is often associated with binding parts that restrict flow. Lubeguard will definitely help if this is the case. Cheap and can't hurt.
It's a v6
UPDATE: dealer called and said it's shifting very smoothly now with no hiccups. BUT, it was 2 quarts low and said there are some metal shavings in the liquid. Due to the number amount of questions I've had he assumed I would ask and kept a water bottle full of the fluid for me to check out. My question is, if there are shavings and it is a lot is this car worth keeping or do I try and get rid of it now before it happens again and or gets worse?
yes its cheap & wont hurt, just saying its not really designed for slipping & doesnt say anything about using it for that issue. slipping transmissions are usually more related to worn out clutches.
Again, you show how little you know about transmissions. Slipping from clutches usually involve multiple gears. Fixing a bad clutch requires tear down. It may very well be an issue in the valve body that can be fixed without a tear down.
I would drop the pan and clean the magnets good. That should give you an idea of how bad things are. Can throw in a new strainer as I believe they are fairly cheap. Likely a thorough cleaning with some fresh fluid should be all you need to keep her going..
what? again?? well if you seriously think adding a bottle of lubegard will fix a slipping transmission or that it has to be multiple gears for worn clutches, then i clearly know more than you.
& why do slipping clutches usually involve multiple gears? clutches can go bad in just one or 2 or all gears. i have had transmissions that slipped only on 1-2 shifts, or 3-4 shifts or only going into OD & even only in reverse, its not always multiple gears & is very common to only be 1 or 2. & yes its obvious fixing worn clutches requires tear down, thanks for enlightening us all on that...
so, if its an "issue in the valve body" youre actually suggesting lube guard will fix that? highly doubt that one. or that removing a trans cooler (which he stated he didnt touch & V6's dont have aux trans coolers) will get dirt & "trash" in the valve body & cause slipping? you are aware theres a filter before fluid goes to the valve body right?? & if by some miracle this "trash" gets to the valve body, how will lube guard remove that piece of stuck debris?? i was just stating a fact lubegard is designed for fixing shudder, if it was for slipping it would be advertised that way too.
i wasnt trying to argue with you, but your ASSumption i dont know about transmissions are rather comical. but thats ok, i just remembered you are the guy that thinks maxlife destroys transmissions... yet the link you posted that you found searching google was just some guy that thinks his old already worn trans was damaged from using it with zero proof or logic it was the fluid that caused his issue & 9 out of 10 people in that link laughed at the guy & proved him wrong!
think what you want, but the statements & "advice" you provided in this thread & the maxlife nonsense are flat out wrong. have a nice day.
Yeah. You don't like me. I stand by what I wrote. Bash away...
H.Sikina
