help!!! vsc trac abs lights are on
b0181
I have an 04 4runner that the trac abs an vsc lights are light.Im getting codes c0205 c1223 c1236 i replaced the left wheel sensor the sensor wire did a zero point cal even changed the break switch and the codes and light come back on in less than a 1/4 mile down the road.Im running out of things to try.
Did you check the wire/harness connecting the abs sensor for damage? My lights are on due to a damaged wire inside the harness.
Easy/Stupid question, but have you checked pressure and aired-up all of your tires? I had the low tire pressure light come on and disregarded it, thinking it was on because of how cold it was outside. After a couple of days the VSC TRAC Off lights came on - all it took was getting my tires up to correct pressure and they went away. Have also read where it can be due to a loose gas cap - doesn't sound like you're getting that code though. If that simple fix doesn't work, you'll probably need to look into what ebg18t suggested.
