help with headlight bulb replacement on 93 4runner
busbeepbeep
Member
I have a headlight that went out. I bought the replacement 9004 bulbs that fit the truck.
What's the best way to access the rear of the headlight to change the bulb?
remove the battery for the passenger side. remove the top half of the air box for the drivers side. make sure you unscrew the ring that holds the bulb in place. then it should just pull out. dont touch the bulb either, if you do, wipe it off.
