Help with tire size for Icon Stage-2 Lift
[MENTION=66316]1engineer[/MENTION] do you know if the speedo diff on your link would be the right % to put into a Scanguard ii for speed differential? Thinking of getting one but have no idea when its comes to calibrating the speed
Your OEM Speedometer is probably off one to two percent. Give me your true tire size and I can calculate the percentage between tires which will give you a differential in percent.
[MENTION=66316]1engineer[/MENTION] thank you, appreciate it! W: 9.2" (online says overall 11.5"), h: 31 5/8" (online 32.8"), circumference: 102.75"
Thanks again sir!
Do you guys mind me asking if you installed the stage 2 yourself or had the kit installed in a shop? Trying to get a sense of what a fair price is to get it installed in a shop. I was quoted $600 here. Seems steep.
Also - I have the tubular arms
Price will vary greatly from region to region as well how much similar work the shop has done. I had quotes in the north east at double that for an install.
delislerebecca
