Help.
Wizzle93
So the shop just called they installed my lift but said my xreas have been leaking. I don't have 400 to get new shocks for the front and back, how long should i still drive with them leaking? Is this dangerous?
Yes and No.
Depends. Shock leaking will cause you to bottom out, and jump up. Stressing other components. It will also impact stopping ability.
It also depends on the degree of the leak. You may have "some" time to fix it.
Only you/shop can tell, as they are looking at it. But, the best course of action is to correct it as soon as possible.
3"spacer lift with rear coils. Alright we'll i guess ill see how bad it is when i go pick it up today. So if i go with blistein shocks in the front and rear could i still use the spacer if i adjust the shocks to 1" make it a 4" lift? So therefor not just wasting what i just bought?
Be careful when going over 3" on a lift and not having new UCAs, also keep an eye on those shocks.......that can be an expensive repair!
goddesszilla
