4RunnerKyle
helping a friend install a new used motor in his 1997 T4R to replace a motor with a blown head gasket...... got it installed in the engine bay, connected the bell housing to the engine and went to rotate the crankshaft pulley clockwise so we could bolt together the flywheel to the torque converter and it just would not move at all.... I can't think of anything that would prevent it from spinning with a breaker bar so i can line up the holes
it just had a timing belt done by the shop that sold us the motor... could that be the reason why it wont turn as it seems as the timing marks may be way off.... the top two pulleys seem to be aligned with each other but the bottom one seems quite a bit off.... could it be this?
left top
right top
bottom pulley... the white speck on the pulley is the timing mark
if not this... what could cause the crankshaft bolt to not turn at all.... Help... it took us forever to get the motor in and aligned and the transmission on and now we're at a roadblock
left top
right top
