Help!!!!!!!!!!!!
peppinggrier
Have a 98 4runner limited and the rear window doesn't work. The rear hatch doesn't open just makes a click but won't catch. Power seats are also inoperable. The rest of door windows work also the sunroof with no problems. Have saw and tried previous posts and tried for the rear window and no luck. Fuses all check out also and everything is good. Any help is greatly appreciated!!:attention:
Bust out your multimeter and start digging. See if there's a load at the rear window plug when the switch is pressed. If not, try the same thing while attempting to adjust your power seats but with the power seat plugs instead.
If there is in fact a load when the rear window button is pressed, then take the rear panel off and see if it's not obvious why the window isn't moving. Look for binding, or a derailed window pane. Start with these two tasks and then report back.
Crookedcat
