HID install help
Jwaz71
Hey guys, im new to 4 runner world and this forum also, so I'll make a introduction on me and my runner later after work, but I had a quick question I wanted to get answered for when I get home.
I purchased the DDM Tuning 8K HID kit, and was wondering about the harness. On other kits I've used it was literally plug and play, but this kit (the h4 hi/lo kit) it has a special harness. In it, it has a red wire with an in-line fuse. I'm assuming this goes directly to the battery correct? It also has a two stand alone black wires that connect to the bulbs and have a terminal rings on one end, where do these go? Those were my main concern. Everything else in self explainable, and plug and play. Thanks for any help. Have a good day.
I have Bi-xenon from an infinity fx, I had to use a relay that was p'n'p from the retrofit source. Not saying this is the exact one but THIS is what I used. I am not sure if that helps or even answers your question but email the guys over there. They helped me a great deal and had the answers to all of my questions.
The red wire with the in-line fuse goes directly to the (+) side of the battery. The black wire with the C-shape terminal ring is a ground. There should be one for each ballast or ignitor, so ground it close to the corresponding side.
I just installed the same kit into my truck (5000k) last week, There are two grounds and the power cable. Make sure to use some sandpaper or something to ensure you are getting a good ground connection. The only other thing you have to do is plug your connecter in that used to go right into the back of the headlight into the harness.
ShiftHarbor683
