Hid projector retrofit question
note to self don't pair gat 2.0's with fx-r lol Panamara shourds fit fine with out issue too :D
Panamera shrouds do not fit either. They require lots of cutting and trimming. I think they are worst ones I've seen compared to the work I've seen others do on other shrouds.
When you say fit are you talking in the headlight or over the projector? Because I know they will need to be trimmed most likely to fit the tacoma housings, but not over the projectors them selves.
Here is how much I had to trim for it to fit over the projector and be flush with the insides of the headlight. I guess it might be different for the different projectors maybe, I don't know. In using the mini d2s projectors so that could be a reason why.
<img src="http://i1350.photobucket.com/albums/p779/zacforsale/60D55511-8F11-426C-8B1E-80CDAFE8A74C_zps2kvuhh1c.jpg" border="0">
Oh my! Yeah FX-R's sit out futher into the headlight depending on how you put them in since it is all custom cut with no set mount. I'm sure that a little trimming will be needed for the Tacoma I'm about to do, but I don't think It will be anywhere near that much.
Gatling Gun 2.0 didnt fit over the projector for me. I had to dremel inside the shroud and grind it all down.
TerryNap61
