HIDS in a 2014?
MEMO CAMPOS
Anybody install HIDS in 14 yet? Of so can you post pics of the installation of the ballast and wiring. I was just looking at mine the other day and noticed the bulb is enclosed behind a plastic cover and just cant figure out how I would run the ballast out of there. I'm assuming that cover is to stop water from going in the projector housing...
I haven't seen it, but I've had experience with similar headlights. Is it a dust cap that screws on? If so, you can just go ahead a drill a 1" hole in the cap. Post pics of the back of the assembly if you can.
Yes it does look like a dust cap and it does just screw on. I'll take some pics soon...
Check this out Memo,
http://www.toyota-4runner.org/5th-gen-t4rs/155229-2014-headlight-bulbs-2.html
I tried sylvania zxe last week, but returned them the next day, because they didn't work as good as I expected. Now I'm thinking about those retrofit HIDS.
I don't think you can fit the whole ballast into that slot, may have to drill a bit in the center just for the wiring. Not 100% sure, but I asked him in that thread.
That's what you do, you drill out the center of the dust cap for the wiring. There should be a round rubber piece on the wires of the bulb which should cover the hole.
