HID's only work on high beams - 01' 4runner
r3tro
So I decided to install a HID kit on my 01' 4runner and problem is only my high beams are working and not my low beams. I can't seem to figure it out and sadly I can't drive my 4Runner in the night time with my high beams blinding everyone and I don't need a ticket for this either haha. Some help would be much appreciated, thanks!
you sure it's not your low beams? With nothing but an aftermarket HID kit, your bright lights won't work any longer. With brights engaged, the low beam circuit loses power.
As soon as I start my 4Runner, lights are automatically on high beams already when I go to turn the headlight switch to on it should switch over to low beams but it doesn't..
What kit did u use?
VVME Bi-Xenon
u probably have to move the prongs around in the harness...thats usually the problem
I played around with the prongs on the harness switching them around, no luck though still only high beams are on.
It sounds like you didn't disable the DRL circuit?
Quoted from an old post:
"When installing HID lights in a 2001 or 2002 Toyota 4Runner (Bi-Xenon H4 HID Kit), you need to disable the Daytime Running Lights. This is because the DRL circuit lowers the voltage to the stock halogen light bulb in order to create the DRL effect. When installing HID's if your truck sends the 6v signal to the headlights for DRL it will upset the new HID ballast and the xenon bulb will flicker like a strobe light.
The fix for this is to disable the DRL circuit."
