Higher angle inner CV joint options for 4th gens?
Bump, I think RCV is back but their axles are crazy expensive.
I was just thinking about this the other day, that it would be cool to have a bit more travel without installing longer a-arms. With my setup though the UCA uniball cup hits the spring on full droop, so I need to clock the spring so it clears between the springs. Maybe I need to machine some of that UCA uniball cup down too. If I want even more it looks like I could throw on a top spacer and machine the cups down on the axles. Would be cool to see the travel numbers I could get.
I did this a while ago since seeing this thread, figured I would throw the information in here and not just my build thread:
I will be machining them like what Dirt King recommends, for good measure.
22* taper, machined the cup back .050" for good measure, then chamfered all the edges.
Aftermarket vs Inv4drZm specials
I used both the SDHQ boots, the All Pro boots called for reusing part of the factory boots, which I threw away earlier and also thought was a stupid idea.
This is fantastic information. Just ordered long travel everything for my rig and was researching this for the last few days.
Another interesting way at going about it.
Just some feedback as referenced in post numero uno, I have been running my setup for about 4-5 years now and I have not once had any issues. No bind, abnormal wear, cv boot issues, etc. I'm not even running a diff drop as I personally don't think it helps much (it didn't then...).
I'm fully confident in this route I took.
Sent from my Pixel 2 using Tapatalk
REE
