Home Brew Whip Mount With Pictures
Snowy21
Well it's not really home brew but just my take on the drifter mount that is so popular, so I must give credit where its due. I just couldn't justify over $50 for a mount when my whole CB setup was just a tick over $100 and I had some extra flat stock laying around the garage.
I am writing this as I make some adjustments to it so don't be too confused when the pics don't totally line up in chronological order with the text.
To start I measured out from the hatch stopper and cut two pieces of flat stock long enough to safely clear the tail light. Then butt welded the two pieces together to make for a big enough area to get both bolts through to the body and give it some lateral support. Then cleaned up with a flapper wheel. Far from the most glamorous solution but with limited tools and skill it seemed to be my best option.
IMG_0212.jpg~original
Then I cut out some square/rectangular pieces to form the actual mounting surface and welded the top on first and then the side as squarely as I could. I welded both sides and just went back with the flapper wheel on the outside to clean things up.
IMG_0215.jpg~original
IMG_0216.jpg~original
IMG_0218.jpg~original
And thats about it, painted it up and called it a project well done with zero incurred cost to me.
IMG_0219.jpg~original
IMG_0221.jpg~original
IMG_02321.jpg~original
In retrospect I wish I had made it extend another inch to the drivers side to clear the hatch better when you open it up but its still pretty workable with the spring, just have to pay attention when you close her up.
And yes I went back and put the coax out the vent, didn't research how I was routing the coax before I took pictures :ybrick:
Nice work.
I think most of us would prefer to build ourselves but a lack of welding gadgets is a problem.
alexaturner
