How do i replace my 2nd gen's headlight...
tkh329
Alright, i realize the answer is probably extremely simple but to be honest after messing with the assembly for 15 minutes and making no headway... i have no idea how to replace the bulb. Also, the seals seem to be letting in water when i take the truck mudding... Are the seals/assembly relatively easy to replace? When it comes to cars I unfortunately am clueless but i'm determined to do something simple like this myself. Thanks,
Tristan
Actually headlight changed in 1992 from sealed beam to replacement bulbs.
Check the lens for cracks. If none then check the seal where the bulb goes in. if all is good then you probably have a leak at the lens and the base.
Mike
Oh yeah to answer the replacement of the old headlight, First you will need to remove both side marker lights. Then you will need to remove the front grill. Finally you will see the bolts that hold the headlamp on, just take em off and replace it!
Mike
Laredotx
