How do my fluid change #'s look?
SummerallGuard04
Got a '99 T4R 2WD, 4 CYL automatic and am just looking for some confirmation on my fluid numbers before I go out and buy too much/not enough:
Replacing the power steering pump--4 QTS? (DEX III Redline, Royal Purple, etc...)
Rear Diff. drain & fill--6 QTS? (Mobil-1 75W-90 Synthetic)
Tranny flush--10 QTS, 11 QTS? (DEX III Toyota WS ATF)
Do you have a manual? Most of this info is in your manual. If you don't have a manual there is a downloadable one in the sticky section. Your rear diff. Measurement is way off. Look at manual.
Yup!
All in the manual. Don't hold somebody else liable for information that's at your finger tips.
Not trying to be an ass, but EVERYBODY should know where to look for this info.
I've got the manual in front of me--for an automatic transmission, two wheel drive models = up to 1.7 qts is the capacity. A transfer (I'm assuming that's a flush?) = with lever/button type front drive control VS with lever type front control? I dont understand the difference...1.1 qt? That can't be right.
Differential oil capacity, w/o e-lock is 2.6 QTS. I got that. I should be good with 3 qts.
I'm still confused. Can't find exact power steering fluid level.
Help. :(. Sorry guys...
wwarren702
