How do you change the oil in your push mower?
Presta24
I have changed mine a few times and can never get all the oil out! Any tips? Mine is a CraftsMan with no drain plug, u have to tip the stupid thing over.
I have the same problem, but alter the position of the mower when it is upside-down. Tilt it, shake it and rock it a bit -- until you don't get even a drop coming out of it.
When you put in the new oil, be sure to check the level. Most small mowers take (I believe) 22 ounces.
There is a plug at the bottom of the engine. Sometimes its hard to get to, remove blade, remove dust cover. But with that method you will get all of it out
You can warm it up for a few minutes (just 2 or 3), usually gets the oil warmed up a little and will flow better. I do that on my Suzuki LTR450 quad with no issues. Don't let it warm up for more than 2 or 3 minutes or else you might burn yourself.
Thx eh :) Mail me some Molsen Hi-Dry dawg :beer:
Lawnmower Oil
I have a lawnmower with a Briggs & Stratton engine in it. I changed the oil and the spark plug yesterday. I had to turn it upside-down AND open the drain plug (use a socket wrench) on the bottom. Dang thing was hard to see because of all the grass caked up under there!
Anyway, get all of that stuff outta there before you fill it up again with the 20 ounces of 30-weight (4 cycle) motor oil.
Your the 2nd person to say there is a plug under there, guess Ill check this time. I was pretty sure it doesn't have one.
Clocktower07
